Sawing frozen veg. ...
[Closed] Sawing frozen veg. Specifically broccoli.
[#2786394]
I really enjoy the convenience of frozen broccoli: it's always there and ready to use in the freezer for a quick 'n' easy curry or bake.
The trouble I've found is that often the broccoli are too big for the purpose I have in mind; the finished dish often has large, unwieldy florets in it doing Titanic iceberg impressions.
So I need to cut these badboys down to size. You might suggest thawing and then chopping, but I always chuck the frozen broccoli straight into the dish. Thawing would remove the convenience.
Thus I wish to cut the broccoli whilst it's still frozen and continue to store it in the freezer. I intend to use a saw for this purpose.
The broccoli will no doubt warm up and commence the dreaded thawing whilst being sawn so to avoid this I wonder if you fine folk have any words of wisdom to impart concerning:
- Saw type: would a hand saw or an electric saw be best?
- Blade type: regular steel or one of those fancy diamond ones?
- Teeth density: 30 tpi or woodsaw...?
Thanks for your help.
p.s. I really quite like broccoli.
Posted : 24/05/2011 9:39 pm
W.T.F.
Posted : 24/05/2011 9:40 pm
Thread of the goddamn year. FACT.
Posted : 24/05/2011 9:41 pm
Nobby Nics...
Posted : 24/05/2011 9:42 pm
Throw it in a food processor
Lasers!
 ton
Fortnums do a good broccoli saw
Posted : 24/05/2011 9:43 pm
Water Knife I think
Do you have a jigsaw handy?
Posted : 24/05/2011 9:44 pm
Posted : 24/05/2011 9:47 pm
yeah, do the jigsaw whilst waiting for the broccoli to thaw
Posted : 24/05/2011 9:48 pm
Remember to keep the saw in the freezer too.
Posted : 24/05/2011 9:49 pm
Food processor: nice idea but the bits come out too small.
Lasers: would that warm it up too much? Similarly for water knife...?
Nobby Nics: shouldn't really be your first choice of ice tyre...
Back in reality, I can't really afford Fortnum's, but will enquire after their broccoli saw nonetheless.
A jigsaw could work, but isn't the blade a little wide? Might just make a bit of a mush of it.
Thanks for all your help so far.
Posted : 24/05/2011 9:50 pm
mcmoonter has a log splitter that may be strong enough
Posted : 24/05/2011 9:51 pm
Mini Stihl and pretend you're a tree surgeon?
Posted : 24/05/2011 9:52 pm
not broccoli, but mince
ultimately, the answer is to cut it up before putting it in the freezer
Posted : 24/05/2011 10:05 pm
For heavens sake people, everyone knows you just get a broccoli cutting disc for the angle grinder !
Posted : 24/05/2011 10:10 pm
To whoever suggested a jigsaw, bad idea!
[img] http://cherryhillcottage.typepad.com/cherryhill_cottage/images/2008/02/12/add_chopped_frozen_broccoli [/img]
PS. How do we get pictures up?
Posted : 24/05/2011 10:17 pm
Cordless reciprocating saw.
Posted : 24/05/2011 10:22 pm
Lump hammer then sweep the bits up?
Posted : 24/05/2011 10:32 pm
Band saw obviously
Small one
Posted : 24/05/2011 10:40 pm
Thanks again for your replies; they're all much appreciated, even the ones typed with tongues-in-cheeks.
Not much of a consensus approached yet, but hopefully it will come.
Any idea which type of blade would be best for the task?
Posted : 24/05/2011 11:12 pm
I'll dig it out the Land Rover in the morning, but can't confirm it's vegetable performance. May want something with less off-set and less coarse.
Posted : 24/05/2011 11:23 pm
Cook til soft, mush about til in bits.
Posted : 25/05/2011 9:11 am
no no no no - who are you my mum ? the ability to turn any vegetable grey mush by over cooking ...
veg needs crunch
Posted : 25/05/2011 9:13 am
Why arent you floretting* your broccoli before freezing? Ideally you could wrap each florette in it's own little bag to.
* real word. No need to check.
Posted : 25/05/2011 9:19 am
veg needs crunch
I hate crunchy veg.
Posted : 25/05/2011 9:20 am
[img] ?ts=634292789052[/img]STEP AWAY FROM THE POWERTOOLS
Posted : 25/05/2011 9:39 am
I'd use a junior hacksaw I reckon with the finest toothed blade I could get my hands on.
Stick it in the freezer as well and chop on a slab of frozen carbon dioxide to stop it thawing.
Posted : 25/05/2011 9:49 am
Broccoli & finger curry ...lurverly
Posted : 25/05/2011 9:55 am
electric carving knife ?
*runs away for verging too close to common sense*
Posted : 25/05/2011 10:01 am
 cp
scissors after it's cooked? too sensible for this thread maybe 🙂
Posted : 25/05/2011 10:04 am
Standing further away will make the broccoli smaller.
Posted : 25/05/2011 10:09 am
I think a very stern letter to Sainsburys is in order. Possible copy in WatchDog, and maybe your local MP.
Posted : 25/05/2011 10:13 am
if you freeze it to a low enough temperature then the bits just shatter when you hit them with a hammer.
Posted : 25/05/2011 10:17 am
I googled "Brocoli Saw" and got this thread!
I didn't want to click the link in case i break the internets
Big knife maybe - if a cleaver goes through bone it should be able to chop frozen veg
Posted : 25/05/2011 10:37 am
Hello again, and thank you for the continuing ideas.
Why arent you floretting your broccoli before freezing?
I buy the broccoli frozen and have no say in the floretting process though this:
is an excellent idea. I shall get on it.
Posted : 26/05/2011 11:17 am
I suppose defrosting it, then cutting to the required size, before putting in your freezer would be too easy?
Posted : 26/05/2011 12:10 pm
As above, use something similar to a Cleaver, no teeth, just a sharp edge and a lot of power.
Posted : 26/05/2011 12:20 pm
Use a cutting implement of your choice to create the perfect sized floret (an axe is the most fun), and then dip the friction heated end of the floret you wish to put back in the freezer into the pot of nitrogen any good cook has nowadays.
Essentially you've undertaken a surprise defrost/freeze cycle - as it should only take a few seconds, nasty microbes and wotnots shouldn't have time to do whatever it is they do, as they would have been napping.
Posted : 26/05/2011 12:22 pm
 emsz
This is why I love this place :mrgreen:
Posted : 26/05/2011 12:29 pm
one more use for quantum torpedoes
oh, and I was once told there is minimal heating from lasers since the photons take any extra energy away with them.
Posted : 26/05/2011 12:33 pm
