SantaCruz Superligh...
[Closed] SantaCruz Superlight frame owners, what forks you guys running?
[#1114103]
I'm waiting for my frame to arrive and need to get some forks, I want to keep the bike as light as possible.
Need a lockout option, would also be nice to have 100-120 externally adjustable.
Any suggestions? - my budget is under £500
TIA
Posted : 09/12/2009 8:22 am
 LeeW
I had 08 Fox Talas on mine, cost me £400ish last August from the states. I wish I'd have stuck to some fixed 100mm forks because I couldn't get used to the bike when they were set at 120mm.
Posted : 09/12/2009 8:35 am
Fox F120, or Reba's are internally adjustable between 100-120mm.
If you go for external travel adjusters you will be adding weight.
If your buying new Reba maybe your cheaper option.
I'm hoping to have the money together soon for a Turner DW Flux & bought some 2 month old, mint, F120's for £321, for the travel option & light weight.
Lots run the Superlight at 120mm.
Posted : 09/12/2009 8:49 am
running 08 u-turn revs, but mostly at 120mm, only dropped 'em down a coupla times. if i had the cash for new forks i'd get 120mm rebas with stiff axle thingummy.
Posted : 09/12/2009 9:34 am
100mm Rebas
Posted : 09/12/2009 9:47 am
Reba sl's. Cheap as chips on Merlin just now.
Posted : 09/12/2009 9:50 am
100mm Reba's here too. They have the poploc but frankly I'd prefer them without. The lever takes up room on the bars, it sticks a bit, needs another cable and is either ON or OFF. I have RockShox forks on another bike and it's easy enough to reach down and turn the compression lever by hand.
Posted : 09/12/2009 9:51 am
Rebas here too, older ones (115)
Congratulations on your choice of frame, its a mega bike.
Posted : 09/12/2009 9:58 am
Reba Race set at 100mm with poplock
Posted : 09/12/2009 10:02 am
115m Rebas
Posted : 09/12/2009 10:07 am
Reba teams 09... perfect.
[img] ?t=1260351827[/img]
Posted : 09/12/2009 10:42 am
100mm Reba Teams
Posted : 09/12/2009 12:21 pm
Posted : 09/12/2009 12:34 pm
I'm currently saving up for a superlight frame only as i want to swap as much over as i can from my rock lobster which has reba teams.
Not sure on what colour to go for so pictures would be good, quite fancy red but not sure.
Posted : 09/12/2009 3:22 pm
have used both Fox F100 and F120 on mine, much preferred the 120s TBH 😀
Scottlacey, i'm selling my frame in the new year, PM me if your interested, its a 2008 Ano Blue, Medium.
Ta
Tony
Posted : 09/12/2009 3:36 pm
Tony
Might be interested
Condition, Pictures and price to sjl@sjl4.orangehome.co.uk
Scott
Posted : 09/12/2009 3:39 pm
ok mate, will send you some info over when i get home from work
Tony
Posted : 09/12/2009 3:45 pm
Sounds like Reba's then, shame my current ride only has 80mm Reba Teams on 😐 could have used those....
Stiff called me this arvo', the frame is having the King headset and XTR chainset fitted in the morning, it'll be delivered to me on Friday 8)
I've upgraded to the RP23 rear :mrgreen:
Posted : 09/12/2009 7:45 pm
 Mole
Another vote for 120's here.
Posted : 09/12/2009 7:57 pm
megastream - take the spacer out of your Reba's - you should be able to take old Reba's up to 115mm.
Is very easy to do.
Posted : 09/12/2009 8:26 pm
what stem length you running with a 100mm fork. finding 90mm very twitchy on my super. surprised to find something as long as a 110/120 run on the carbon blur in the last issue. any suggestions welcome. can include ones on grammar too!
Posted : 09/12/2009 8:37 pm
Dickie
Is very easy to do.
I would like to try this on my reba teams.
Any instructions/pictures on what to do?
Scott
Posted : 10/12/2009 9:10 am
[url= http://www.sram.com/_media/techdocs/95-410-762-000%202006%20Pike%20Reba%20RVL%20Dual%20Air%20Service%20Guide.pdf ]Service manual[/url]
Page 4 - usually its just a fat clip on the rod.
Having looked at the diagram, I'm not sure it can be done on 80mm's.
Posted : 10/12/2009 9:36 am
Reba teams here too. I would have thought the 80mm Rebas just have ALL of the travel adjust spacers in. Should go up to 115mm - 120mm by removing them?
Posted : 10/12/2009 10:06 am
120 Here too
Posted : 10/12/2009 2:04 pm
