Can’t for the life of me work out where this is coming from.
Most of the time, no issue, but if I hit a fair old dip, like a bomb hole, and compress enough, I get a loud knock like frame hitting something kind of knock. Not sure if it’s on full compress or uncompress. Doesn’t always happen, but needs a good firm compress on the rear to do it.
Sounds like the rear. Fork isn’t bottoming out, no where near. Rear shock isn’t either according to the rubber ring.
Checked lower link rubber stop and that’s present.
Just can’t see what’s doing it or what could hit the frame in that way. Pretty sure it’s not the chain slapping against frame. Different sound anyway as it does occasionally, but it’s under tension with the clutch mech and even on rare occasions it hits the frame it hits the rubber chainstay protector.
It’s only recently started doing it. Have serviced rear shock (Monarch Debonair) and bushes plus replace mount kit with TF heavy duty kit. No play in that. No play in BB. Mech seems fine.
Only vague thought is the bottom of the upper link potentially hitting the frame on uncompress but I can’t see how as shock fully extended there’s still a gap between it and the frame.
Baffled.
