Samsung Galaxy S2 B...
[Closed] Samsung Galaxy S2 Battery Life Dropped Off
[#4809936]
My Galaxy S2 is just over a year old and all of a sudden the battery life has dropped to a few hours rather than it's usual day. I am not using it any more than nornmal, it just doesn't want to hold a charge. Is the battery likely to be on the way out after 12 months? I thought modern batteries had longer lives. Or is it likely to be something more sinister?
Posted : 29/01/2013 12:18 pm
Have a look in your task manager, I found some apps were not stopping * and using processing power. set them to stop just after the display goes off and it seems to have helped.
* Travelline i'm looking at you
Posted : 29/01/2013 12:22 pm
 P20
Wor lass had something similar. I got so fed up of it i bought her the bigger battery from Amazon. Its only about £17. Its tricky to tell if it was just a tired battery or not, but the new one is a lot better
Posted : 29/01/2013 1:08 pm
nope your apps have caused a conflict in your programmes. factory reset the only solution
Posted : 29/01/2013 1:09 pm
You can look at your battery usage history and see what apps have been using the power or if you're phone has been kept awake.
Posted : 29/01/2013 1:10 pm
factory reset poss.
but also as said above, change the battery - they're very cheap.
I was having battery issues and found that turning off background sync for apps had a massive improvement in battery life and it also seriously improved my data usage.
Posted : 29/01/2013 1:15 pm
Screen brightness increased? A real battery killer...i find if i have my brightness at about 40% i get 2 days out the battery. If brighter it lasts a day...
Posted : 29/01/2013 1:31 pm
What is the top app based on battery use?
Mine was google+ (used 80% of the battery!) only thing that worked was uninstalling it.
Posted : 29/01/2013 1:34 pm
I've noticed mine turning itself off and on a few times a day. No idea why and not really sure if this is happening so much that it is hammering the battery.
Posted : 29/01/2013 1:44 pm
Have you updated the firmware lately? Jelly Bean doesn't seem as good on battery as ICS. As said above google+ can be a big battery muncher as it stops the phone from ever entering deep sleep.
Posted : 29/01/2013 2:01 pm
