Interesting (or not) fact/anecdote about running in.
It used to be important because nothing in the engine was smooth, so it too a few hundred/thousand miles before the engine had worn off all the high points. thrashing it too early and it would get hot and sieze or wear away too much metal.
Modern engines are built to much higher tolerances and therefore sometimes require a cheaper oil to actually add some friction during the running in (usually mineral oil, and the advice was not to use stuff like magnatec).
And the anecdote bit, Honda once accidently sent one of their GP bikes out for practice without filling with oil. It came back running a little hot. Having rectified the error they stuck the bike on the dyno and it actually made more power than the new engine thanks to the increased tollerances!
