Hi,
If im running a 1 x 9 set up, do i need anything to keep the chain on the single ring at the front? If so, whats the lightest solution to doing this? I don't want to shed the weight of the inner and outer rings only to have something as heavy replace them.
Also, will i be able to run a short cage rear mech with a standard range XT cassette??
