(RS) Steerer tube r...
[Closed] (RS) Steerer tube replacement? Is it the done thing? How safe?
A fair few areas around the headtube have got flaking paintwork as a result of it too though
So if it had been near to breaking point then there should/ought to be signs of flakey paint/stressed paint?
Just throw it away
Posted : 24/02/2010 12:21 pm
cynic-al, but you could ream the crown hole and go up a size on the new steerer if he was to go down the route of getting one made. Were only talking hundredths of a mm here.
The thing is, if in doubt bin em out. Give you postage for them 😉
Posted : 24/02/2010 12:22 pm
"bin em out"?! What's this, making up phrases to fit a ryhme 🙂 ?
Posted : 24/02/2010 12:26 pm
"Just throw it away "
Its not my bike to throw away, its my brothers, I don't think he wants to have to drop £1200ish on a new frame when he 'can' still ride this one. Plus you can't get a QUAD-link frame frame-only
"but you could ream the crown hole and go up a size on the new steerer"
As new, the part of the steerer tube that press fits into the crown is the same outer diameter as the part where the headset crown bearing race sits, (presumably 30mm as per that RST one, so that all crown races fit all forks), then tapering back to 1 1/8" for the rest of the fork? (the bend is above this transition point, probably about 40-50mm higher
Posted : 24/02/2010 12:27 pm
Yeah pretty much.. I am very bored. 🙂
My mate fitted an alloy steerer to some single crwon Marzocchi shivers. The original was steel and way too short. He did the heating the crown up trick and then freezing the alloy steerer tube. Thus making a press fit. He even used a different steerer tube, think it was a Rockshox one he bought cheap. Bike has been running no problems, hes a fairly burly lad too. I doubt the crown strength will have been compromised. Just dont go too much with the heat on the crown, boiling water will be enough. Heating it a lot with a blow torch too much would compromise the crown strength though.
I would ride with that no problems.
Posted : 24/02/2010 12:30 pm
[i]which forced the headset to ovalise the headtube in the bike[/i]
[i]Bike has been running no problems, hes a fairly burly lad too. I doubt the crown strength will have been compromised[/i]
talk to Marin about a crash replacement front end.
I can't belive people (particularly 'burly' people) treat their own safety with quite so much contempt...
Posted : 24/02/2010 12:34 pm
whats a Marin front end got to do with the price of fish?
Posted : 24/02/2010 12:40 pm
The most annoying thing about the whole thing, is that had the bike not had a handbuilt front wheel and some poorly tensioned with some miles under its belt factory built front wheel, the front wheel would probably have pringled and left the frame and fork completely unaffected. Thanks merlin!
Posted : 24/02/2010 12:42 pm
seth-enslow666 - he said it was a quad link frame - aren't they made by Marin?
Posted : 24/02/2010 12:46 pm
yes but I thought he said the headtube had gone oval after the crash? Why not just hit the headtube and make it round again. Stick a bit of round pipe in it for a guide and hit it until the headtube is round again, a bit like a blacksmith!
Posted : 24/02/2010 12:51 pm
Above comment was facetious and should not be takem literally!
Posted : 24/02/2010 12:54 pm
Marin do make Quad-link bikes, but they're not the only one ..
Posted : 24/02/2010 1:06 pm
 ojom
I will sell you a new CSU at trade if it helps you NOT press in a new steerer.
Please don't mess about with stuff like this. An impact that has damaged your headtube and split a set of forks could easily happen again and you will not get lucky twice.
If you want some help then please drop me or Colin and email to mdownie@thebikechain.co.uk with the exact model and i will sort you a price.
_-_-Mods - please feel free to delete this if deemed inappropriate-_-_
Posted : 24/02/2010 1:37 pm
Whats a CSU?
I'm not thinking of riding it (anymore), mostly interested in the detail
The fork hasn't split, just bent lots. The pic is after the steerer tube has been forced out of the crown
Posted : 24/02/2010 1:42 pm
 ojom
Steerer assembly. The upper legs basically.
Posted : 24/02/2010 1:43 pm
Steerer, Crown + Stantions. Oh I see, CSU, stantions being uppers
Erm maybe yes, I don't need to get the fork off of my brother, just that if rideable would be better than the MX pro on my HT
Its just that the costs could be a bit preventative, though I'd be prepared to swap at home with the help of the rockshox manual
A complete 'CSU/SCU' assembly would put my mind at ease
Posted : 24/02/2010 1:48 pm
 ojom
Drop me an email on above address and i will find out the costs for you.
Posted : 24/02/2010 1:52 pm
YGM
Posted : 24/02/2010 1:54 pm
 ojom
Ta - will get back to you soon.
Posted : 24/02/2010 2:07 pm
Mate, your brother is gonna die on those!
And that looks like a "soft" landing too!
Posted : 24/02/2010 2:28 pm
I'd be more worried about the frame and the headtube than the forks. Forks can definitely be fixed and the best way is with complete new upper section. Frame on the other hand sounds like it needs the attention of someone with experience of aluminium fabrication at the least (e.g. fix by welding and re-machining headset cups), and may be destined for the bin.
Posted : 24/02/2010 2:57 pm
What's the worst that could happen?
Posted : 25/02/2010 11:53 am
Page 2 / 2
