I have a pair of RS Revelation 426 dual air forks, with 130mm travel. Does anyone know if the travel can be adjusted internally, and if so to what? Is it simply 100mm or 130mm, or could it be set up to 115mm?
Ta
Ta
I'd say it was the same as Tora/Reba and a 15mm step.. 100/115/130
Assuming there covered by the 2005-2006 manual (as there 130's not 140 or 150's)
Under the section ALL-TRAVEL CONFIGURATIONS
http://www.sram.com/_media/techdocs/95-410-762-000%202006%20Pike%20Reba%20RVL%20Dual%20Air%20Service%20Guide.pdf
...so did you pay the £700 or did you get the bike any cheaper than that (I ask as there one in anohter local store)
Cheers Z1ppy - YGM shortly...
Yes you can pack them down in 15mm increments, I have mine down to 115mm and it's great. I think it needs to be done at the same time as a service ideally.
The duel air forks have 2 springs so if u pump the negativ spring the fork gets shortar and if u pump the posativ spring the fork gets longar
Have a look at this as well
That also changes the feel of the fork. Not a good idea really.
Thanks everyone
