So i was fiddling about on my revs this evening after a day on the quantocks yesterday, my forks have never felt properly plush no matter how i set them up, hence the fiddling this evening.
So setting sag, +ve chamber at 120psi then started the -ve side i noticed the -ve chamber was at 100psi, so i inflate to 115psi then re check and its back to just under 100psi..?? done this around three or four times inflating to up to 140 psi then re checking …every time its right back to just under 100psi, is a seal gone , as i just can’t get the pressure above 100psi.
is it service time?
oh and with the poplock version is there no compression adjust ?
I have the floodgate on full as i like full lockout on the climbs..
any tuning tips appreciated cheers.
