Viewing 15 posts - 1 through 15 (of 15 total)
  • router question
  • joolsburger
    My Linksys router's power supply overheated and failed and I replaced it with a spare I had (exactly the same), It now won't give a wireless signal but internet works via a cable through the router's port. Any ideas before I splash out 20 quid on a new one?
    thanks
    foxyrider
    Wireless switched on in the router admin area?
    richmars
    First power supply could have overheated because of a fault in the router (maybe the wireless bit), but check everything is turned on.
    wwaswas
    as above power supply failure caused other issues in router.
    dmiller
    Flash the firmware down and back up – might prod it back to life…
    joolsburger
    Thanks all, can't even get into the admin screen so I reckon it's dead.
    J
    Cougar
    Try a factory reset before you bin it completely?
    joolsburger
    How do I do that? I've connected to it with a cable and can access the web but there is no way into the admin area, it can't find the IP. Have pressed the reset button, no joy.
    foxyrider
    192.168.1.1 or 192.168.0.1 – usually login is admin and password?
    MarkN
    Hve you tried here?
    http://www.linksysbycisco.com/UK/en/support
    Key in the model number and there may be some more pointers for you to try. Some of them need the button to be pressed and held, usually with a paper clip or similar.
    Carpediem
    Most routers will have the IP on the base along with username / password.
    But as you say, it's fine when its hard wired.Have you checked your PC's wireless card settings? Can you see any other wireless networks when you search for available connecrtions?
    joolsburger
    Well tried all of this it's dead !
    Bugger.
    foxyrider
    Can post it to me and I can see if I can get it working jooles? Email in profile 🙂
    _tom_
    If you don't want to spend much I have a Netgear router (brand new, never used) that I could let go for cheap 🙂
    joolsburger
    Just bought another, done. Thanks for the offers.
The topic ‘router question’ is closed to new replies.
