Rooting a desire - ...
[Closed] Rooting a desire - idiots guide required
[#3397395]
My HTC desire is doing the usual "short on memory" thing, as far as i can see the only route (No pun intended) is to root it and get rid of facebook etc.
i need an idiot - how to guide, hints and tips, plus what rom to use. Can i use android 2.3? or even android 3?
Posted : 27/11/2011 6:35 pm
also interested in this
Posted : 27/11/2011 7:08 pm
If you're running 2.2 or above you can move apps to SD. I'd imagine you'd be running at least 2.2. HTC also have a standard release of 2.3 so you don't have to root. You say you want to root it but I assume that's to run a custom ROM. If so choose a ROM and google for details on how to root and instal it. Loads of YouTube clips out there. Cyanogen mod would be a good starter for 10.
Posted : 27/11/2011 7:12 pm
i know you can move apps to sd but its the unmoveable ones that cause the problems like facebook for htc sense (11mb)
Posted : 27/11/2011 7:53 pm
How do you restore apps from SD?
Why not just re-install the unmovable ones? It won't take long over wi-fi
Posted : 27/11/2011 8:01 pm
I don't want one son my phone that are stuck there. The ones on the sd card are fine, thats where most should be as the deisre has a tiny internal memory.
I comes with certain software that i don't want e.g. 11mb facebook!!
Posted : 27/11/2011 8:12 pm
You can uninstall the updates to Facebook, it'll free up the used memory.
Posted : 27/11/2011 8:15 pm
Biggest problem with the Desire is its internal memory storage.
Rooting then using apps2sd+ is a fantastic solution.
The link posted above to Modaco is a great resource and a good starting point if you want to start getting in to custom ROMs.
You also have the benefit of a mature rooting guide now. When I had my Desire it was a proper hassle to root it.
There are a load of ROMs out there, I haven't been following the Desire scene so not sure if Gingerbread is available yet. The Modaco roms are usually a good, safe and stable bet.
If you head over the xda-developers site there are loads more and its another great resource but also typically a little more technical.
Posted : 27/11/2011 8:33 pm
Is it just me that thought "rooting a desire" sounded rude?
APF
Posted : 27/11/2011 9:06 pm
xdadeveloper.org is a bloody good place for everything HTC.
Posted : 28/11/2011 4:35 pm
Just looked at the Modaco link. It's a very old guide.
When I did mine, I used Unrevoked. Seems it's still the preferred method.
There's a collection of documents on [url= http://androidforums.com/desire-all-things-root/163477-desire-all-about-rooting-updated-11-nov-2011-a.html ]Android Forums[/url] which tell you everything you need to know. [url= http://androidforums.com/desire-all-things-root/221212-faq-rooting-updated-11th-november-2011-a.html ]This[/url] is a good starting point - it's a lot to read, but it'll arm you with what you need to know.
Posted : 28/11/2011 4:42 pm
