I had the roof replaced on my house around 10 years ago and thought that would be it for around 20 years.
Unfortunately there are a couple of leaks forming, so I went for an investigate yesterday.
I have a strange roof with an internal trough to take the water from 2 parallel pitches of roof, it then goes “inside” the 3rd pitch which is perpendicular. This trough is made of wood and the roofer relined it with roofing (shed) felt when he did the roof, the wooden battens need replacing.
I have used some grey glass fibre paint in the past to go over lead valleys etc when they leak and am about to buy some more to give the internal valley a coat and some other bits of flashing / lead valley etc which look likely leaky points (and a flat bit of roof that is definitely leaking) ……………..unless any of you wise men have a better solution!
Any advice greatly appreciated!
