The problem with the SC video and that particular whacking against a concrete block test is that it is irrelevant in the real world. They’re whacking a naked lightweight frame against a concrete block and they bounce off. Well no wonder – there is no weight to create any significant force to the frame other than what the man is able to generate – and men are weak and feeble. So what. Attach a fork and a wheel to the frame and do the same thing and the frame would snap like a dry stick (as opposed to bending and deforming as a metal frame would). The only thing it demonstrates is that if you ride into a concrete block you’re screwed whether you’re on a plastic bike or a metal one, so avoid concrete blocks. As a test it’s utterly useless in relation to mountain biking and is just a cheap marketing gimick.
My concern with the 591 style rack is not crushing the tube – you can’t actually apply that much force at the jaws on a 591 – certainly not enough to crush or damage a carbon tube. My concern would be the the abrasion of the jaws on the frame. With my metal bike when I first got my 591’s within a few drives the jaws had worn through the paint and were starting to eat at the bare metal underneath. I now wrap a few layers of Heli-tape at the contact point. I need to replace this every few months or as the jaws wear though the hell-tape. Now I would think, knowing how soft carbon is, that the jaws could wear through the carbon far quicker than metal as it is softer, so causing damage much earlier.
If I were to go down the carbon bike route and the bike didn’t have hard plastic protectors attached on the frame at the jaw contact point, i’d either be using the fork style rack or using alot of hell-tape protection at the contact point when using a 591.
Spence – a mate of mine has one of those clamp to crank arm racks. It works fine with parallel sided crank arms, but when he used it with his mountain bike that had tapered crank arms it slid down the crank arm from the thicker part to the thinner part when on the motorway and I watched as his bike slowly lay down on it’s side and ended up lying down on its side on the top of the car. Luckily there was no damage to the car or bike, but it completed the journey in the boot of my car.
