I have just serviced a 2012 Sid xx dual air, I was very methodical, every seal replaced and everything back in the same place it came from, I have 6ml of oil in lower legs and 106ml in the damper side (I ppoured out 106ml when stripping down) I put every back together and cycled the fork up and down with no air pressure, when near bottom out there was slight resistance then the damper side wiper seal pops out, I did this a hand full of times, did it with oil and xloc fitted and without any oil or xloc. Thinking there was some kind of pressure in lower leg from putting it together and compressing for fork was releasing it? It had however stopped doing this and all seems well?
The one thing I did notice is I measured oil hight in damper side before I drained it, it was 90mm from oil to top of threads. I poured out 106ml and put the exact same back in and the oil hight is not around 80ml?
Any ideas
