Viewing 10 posts - 1 through 10 (of 10 total)
  • Rockshox red rum? alternative?
  • Turnerfan1
    Looking for the above.
    Seems to be out of stock everywhere,alternative or anyone got any spare?
    Thanx,
    Max.
    ryderredman
    Is that external stuff? I’ve seen my mate use normal chain lube 😐 risk it if you fancy!
    Turnerfan1
    No,
    It’s the red oil that you soak the foam rings in to lubricate.
    Not sure what I could use as an alternative.
    Thanx,
    Max
    Northwind
    I just use the same oil as the lubricant bath. IIRC the Red Rum is supposed to be Torco assembly lube but I don’t know that to be true.
    ryderredman
    OH! I remember now, Yeh I just used the motul stuff i filled the bath with
    unklehomered
    15wt fork oil. Job done. 🙂
    teethgrinder
    Pft. Gearbox oil in my revs.
    Turnerfan1
    Ok guys,
    Mite just use the 15wt as have that for the lower legs.
    nealy
    Same as the lowers oil as it’s going to mix with it as soon as you turn the bike upside down
The topic ‘Rockshox red rum? alternative?’ is closed to new replies.
