MBR appears to have done an about turn in the last couple of months and are now saying standard offset is better. Which leads me to believe they don’t know what the f they are on about.
….This!
I’ve tried a 46mm offset Revelation 120 and am now running a 51mm offset Pike 120 on my Camber Evo. Expected to feel some difference in handling/turn in speed between the two, but couldn’t tell any difference. However, the extra stiffness (and possibly better damping) on the Pike is very noticeable indeed – it really improves the bike, although it does show up the crummy evolution shock a bit.
For info., I tested both forks on a local circuit that includes a decent length of flowy singletrack slalom cum pump track (Lady Cannings trail), followed by a couple of rocky Peak District descents.
The Pike is in a different league to the Revs.
I’ve now settled on one, rather than two, extra bottomless token in the Pike to try and match the rear shock in trail setting. Oh, and FWIW, I weigh 90kg.
HTH
p.s. If you look on the Specialized ‘Masterlink’ FAQ webpage, I think you’ll find the 46 vs 51mm offset on Camber Evo question has been asked before – one reply from their tech team says 46mm and another 51mm! That’s when I decided to bung my existing 51mm Pike on the bike! :))
