Eh? No… I don’t think so.
I need a longer bolt for the footbolt on the damper side on a pair of Pikes. I’ve moved the damping to the spring leg and vice-versa as the bottom of the spring leg has a thicker casting due to the IS brake mount being incorporated at this point.
I have fitted a Dual Position air spring, reduced to give 130mm-100mm of travel, but this needs to go on the damper side. As a result I need a 5mm longer bolt for the other side to install the damper. I have rebuilt it, but only 2 threads engaged…
So, I need a slightly longer hollow bolt. I could just use a normal bolt and remove it to (carefully) adjust rebound, or drill the middle of the bolt out, or find a longer one.
I’m not certain of the size.
