Id check the state of the bushings (upper and lower
A worn bushing (down to the metal) is what caused stantion wear on my Revs
Whats a real PITA is since power buldge the lower bushings aren’t replacable. Rockshox have effectively made lowers a wear/replace item, Guessing they’ll be £200+?
But yes, so long as both are the same maximum (unspacered) travel, if not you could have issues with rebound/-ve air lower shafts reaching the base of the lowers and having enogh stantion/bushing overlap?
Id probably go with the solo air setup. imbalanced air pressures can be nice but too compromised IME, either plush but too divey and sucks travel down, or feel a bit too firm if you’re not on it going down the hill. ie up the hill it might not track the same? I dunno. Depends how much dive is a problem for you
Plus both sets of dual-air forks Ive had have leaked in some way such that the air pressure ratio changes (either sucking down or leaking there way to too firm)
Id rather any leak was constantly balanced between the 2 as solo air does when it leaks
Not sure Id sell them as Rev Races though
Double check the specs exacltly
IIRC Revs have floodgate adjust in the MoCo unit. Do sectors have that?
Not sure how an RL sector would differ in the MoCo unit to a Rev
Also, what crown/uppers will it end up with. Not a steel steerer or not slim crown
Im not sure where the weight difference is, but I think sectors are typically 150g or more than revs, might be steel steerer, might be somewhere else. I dont know
