Does anyone use a standard double on the front with an 11-32 on the back
My Condor has a 50/34 front, with an 11-32, 9 spd XT-M770 on the back.
For completeness (tho’ it’ll make dull reading unless you actually want a parts-list 😉 ) I’m using an XT M770 SGS (long) rear-mech, and some kinda Tiagra tripe front mech (with the limit screws set to stop it going too far), and shifting via Dura-Ace 7700 bar-end shifters … and it’s great. (It did have an M810 Saint on the back for a bit, but the return spring on that mech was so strong it used to ghost-shift under load, as the bar-end shifter just couldn’t hold it).
I don’t mind the wide gaps in the shifting, but then I don’t ride in any kinda measured / technical way, so I never worry about maintaining cadence etc … I just ride comfortably along looking over hedges and the like. If I rode a road bike in they way that some people do, I can see why it’d probably not be the done thing.
I’ve also just finished off my old 90’s road bike – that’s a mix of 8 and 9 spd stuff, that’s got a conventional 53/39 front and an 8 spd 11-30 on the back. A mid cage Ultegra rear coped ok with that range (ok, it did for me), but I’ve swapped that for an XT SGS too, just to give everything an easier life.
I have run mid-cage Ultegra at 22/32/44 x 11-28 with no problems (in case it helps – not sure it will as I seem to have just rambled on and on here …) anyway, the point is you’ll probably get away with extended the specified range for things by a little bit (but not too much). 8 and 9 speed stuff feels tougher and more tolerant than 70 speed (in my experience).
