I recently got a new road bike which came set up tubeless (tcr disc). I was experimenting with pressures and one night found out the hard way that I had dropped too low. I hit a pothole and got a puncture in the sidewall near the rim. It didn’t self seal and deflated. I filled it back up with a co2 and tipped the bike on its side with the hole at the bottom it stayed up for a couple of miles but went down again. I topped it back up and rode home. I got home and it was still inflated so i deflated to let the co2 out (heard it permeates faster than air) topped up to 100psi and went back out.
Every ride since (about 5) the tyre has gone down. At first I thought I may have got another puncture but the more I think about it i reckon its the original hole on the side not getting any sealant due to centripetal force. I can hear the sealant sloshing in the tyre so I know there’s plenty in there.
I’m used to mtb tubeless and have had about 2 punctures i have known about in around 5 years and very little other problems. Losing a few psi from a mtb is barely noticeable but the high pressure of the road tyres seems to mean that potentially a lot of air is lost in the short duration it takes to seal a hole. Last night before riding I topped up to 110psi and after 20 miles I had 30psi left and had to limp home.
I’m going to put the wheel in the bath tonight and have a look for bubbles and have a check for thorns/glass etc. If I find a hole i’ll patch it from inside and add new sealant.
So is road tubeless generally as good as mtb tubeless? I’m hoping I have just been unlucky so far.
