I’m 90kg. 25mm Schwalbe Pro One’s tubeless on Hope 20Five rims (20mm internal/ 24 external). Not a seasoned roadie.
The Schwalbes measure 28mm wide with callipers now. I’ve only had them a month, but so far riding on 75/80 front/ rear psi on good roads. I used to ride 80/85 before tubless with latex tubes. I’m on a Roubaix so it’s a very comfortable ride whatever. Might drop them and see how it shapes up in the bends. Information I found was a bit sparse, but I think about 10psi less after you take tubes out all else being equal.
I checked with Hope and the rim can take high pressures if needed, not all rims can, most 29er rims won’t. Grails are another good choice.
