I was wondering the same thing the other day, but was unaware until now of the versa shifters…
You could have the normal Alfine shifter mounted near the centre of the bar, or look into having a bar end shifter modified for the alfine, both quite fugly compromises…
I would guess that an 11 speed version of the versa will be along in due course, but I doubt it’ll be straight away, Alfine 11 is due September-ish? Can’t imagine they’d be flogging a road lever before April 2011 and that’s being optimistic…
On the plus side the Alfine 8 is pretty cheap now, in fact the hub can be picked up less than those levers…..
Would a stop gap 8 speed drivetrain be so bad until an 11 speed hub/shifter is available…
Also what is the OLN dimension on your Van nicholas? 130mm? alfine will be 135m surely…
