Viewing 3 posts - 1 through 3 (of 3 total)
  • Road questions
  • Taff
    About to buy a new road bike so been looking at the PX RT57. Couple of things that I’m not sure on.
    Firstly, will be running compact cranks (50/34)and a 11-28 cassette – I can use a mid length or short rear mech. Which one should I use? Presumably the short would be better suited.
    Secondly is crank length. Been advised to run with 172.5mm. I run 175mm on the mtb but been told with compact that 172.5mm will be better. Seen similar stuff on Google but have no idea why!
    trail_rat
    crank length is nothing to do with the size of chainrings so who ever said that with a compact you are better with 172.5 is talking out their hoop for a start
    50/34 11-28 is a max difference of 33
    a road short has a 29 max on paper.
    thus the mid is the better fit. A road short will work IF you never cross gears …. on a compact you will cross
    Taff
    Thanks trail rat.
The topic ‘Road questions’ is closed to new replies.
