I would like to upgrade the wheels on my 8 year old tarmac, it currently has shimano jobs which came with the bike but the bearings are knackered and the rims worn out. Id like to spend about 300 to 350 and want a light stiff responsive wheel but have no idea about road wheels…….
I recently picked up some Shimano RS81 C24 wheels from Wiggle just over £300, this is the “ultegra” level non-groupset series wheel with the similar carbon fibre / aluminium laminate rim used on the Dura Ace models.
I’ve been very impressed with these wheels, just over 1500gm so light, but feel very fast rolling and much stiffer (rear is 2 cross both sides) than my previous Fulcrum Racing 3 which always felt a bit flexible on climbs. brakes feels very good with Swiss stop blue pads even in wet weather
they also have a steel freehub body which will resist cassette gouging much better than aluminium alloy bodies common to wheels of that weight; my previous wheels including DT swiss and Hope had bad gouging causing creaking
Shimano hubs aren’t compatible with Campagnolo cassettes and vice versa. Most modern wheels come with a spacer to fit most speeds of cassette (11/10/9/8 speed etc)
Be careful. The Shimano wheels are good right up until you need to replace a spoke. They are expensive and need special tools to fix. Also the cone and cup bearings can be problematic to get exactly adjusted.
I think the new Shimano wheels have much easier adjustment, just check they have the ‘digital click’ system, only requires two 5mm allen keys and your fingers, no need to adjust for QR tension etc.
To me it’s the best system out there.
Can’t comment on the spokes though, have yet to snap one on mine.
I’ve got the alloy Ultegra wheels that I got through Wiggle and had to have two new spokes from new in the front wheel that local bike shop fitted but Wiggle paid.
And the digital click makes the cone adjustment simple.
Still wished I went for the standard Hope hoops in 32 spokes though.
I’ve been using cheap shimano wheels, cost around £65 for the pair, on my winter/wet weather commuter on and off for years. Never had a broken spoke and never needed to adjust the hub. The rims wear out before any tweaking needs done on the hubs, but that’s just general wear.
Im a bit of mavic fan boy but your budget is a bit of an oasis for that brand. How about the Cosine wiggle brand, look to tick all the boxes?
If not then Zondas, C24 or C35.
We are about to Ebay a set of Fulcrum wheels (minus cassette) that came off a brand-new 2015 Tarmac we bought for Xmas. The same wheels in this review:
I’ve got handbuilt archetypes on miche primato hubs which are fantastic and cost around £300. That said, they replaced Zondas which I had worn out after a gritty winter of riding. For £220 I wouldn’t hesitate to buy Zondas again. That is a ridiculously good wheelset for that price. They’re stiff, light and incredibly smooth wheels that would be well worth it at twice that price.
People will tell you the spokes are a ballache, but I’ve not a had a single problem with mine in three or four years. Stiff, tough and responsive. There may be lighter wheels, but I’ll take the stiffness of these instead.
They’re way under budget but I’m currently rolling on Fulcrum Racing Quattros, they’re very stiff and also comfortable, slightly aero and look nice too.
Pretty bomb proof too, done nigh on 3000 miles and they’re just showing some signs of wear,
