Viewing 40 posts - 41 through 80 (of 105 total)
  • Road bike… Rim brakes vs discs.
  • prawny
    Love my disc brake roadie. However I ride it 40 miles a day 5 days a week so it works for me. Mine are cable, and they’re OK, if I wasn’t using them so much they’d be fine but the adjustment frequency is a massive pain so I’d prefer hydros
    If I was just riding for fun in nice weather, I wouldn’t be bothered.
    joebristol
    I find rim brakes on my racer are adequate in the dry but in the wet they’re borderline dangerous. That’s on standard aluminium rims (Mavic aksium) Witt updated pads.
    If I could afford / justify buying a new racer I’d go disc without doubt. If there was the same bike with high end rim brake wheels or say mid range discs wheels I’d go disc without a moments hesitation.
    I think it depends on your usage though – I commute about 17 miles a day on the racer in all weathers with the occasional sunny summer ride. That’s very occasional though – if the weather is nice in the summer and I’ve got time then I’d much rather be out on the mtb.
    belugabob
    Probably actually a CX bike, as road bikes with discs seem to have forgotten that I might actually want to fit mudguards
    If you don’t mind building up from a frameset, then the Kinesis Racelight 4S Disc may be worth a look.
    It has the option to fit either rim of disc brakes, can handle mudguards with up to 32mm tyres, gas mostly internal routing ( and the blue one looks gorgeous)
    Other mudguard ready bikes may be available, but I’m biased 😉
    mrblobby
    I don’t think it’s any different to rim brake bikes, if you want to mount guards then get one designed to accommodate guards (typically not a race bike!) There’s plenty out there.
    taxi25
    For a summer bike I wouldn’t look at discs, it doesn’t matter how well the might work I just don’t like the look of them. Besided I’ve done 8,200 mls on my summer bike and Its still on the original brake pads !! They work just fine in the dry.
    If I could only have one bike for all year use it would definitely have discs. I was coming down a soaking wet lane once on my rim braked winter bike and couldn’t stop at a T junction. 😯 lucky nothing was coming but it shook me up.
    mooman
    Much more fun descending long, fast, steep switchbacks when you don`t have to worry about your rims overheating. Ok if you only riding UK, but if your venturing abroad onto longer, steeper descents where you know the rims will be at melting point before your 3rd of way down …
    I`m a convert to them now.
    FunkyDunc
    I don’t know about that I’ve always like the extra grip you get from a hot sticky tyre.
    Pro’s manage just fine descending without rims/tyres exploding. If your tyres are exploding you are putting too much air in !
    TiRed
    Pros manage because the roads are closed ;-).
    Happy with my Ultegra and Dura Ace dual pivots. By contrast, the Avid cantis are nowhere near as good, especially in the wet. I often wonder if this is why people have such poor experience. That and an expectation that braking from the hoods is the correct technique. It isn’t. Brake from the drops and you’ll find its a world of difference. Can’t reach the drops? Adjust your bike properly. You don’t brake on an mtb without wrapping your thumb around the bar, surely?
    That said, I think that ultralight carbon rims and disc brakes are the only natural bedfellows. Just not seen them that often.
    And nobody I ride with regularly has them because BC don’t allow them in races.
    forzafkawi
    A lot of people just assume that the advantage of disc over rim brakes is only power. However, the real advantage for me is the feel or modulation. Dry or wet roads the braking feel is virtually the same with very little if any lag in the wet. You can judge your braking a lot better and it’s not a question of hauling on them to stop quicker. For me they are a lot more consistant and therefore safer irrespective of the road conditions.
    njee20
    but then again on a road bike on the roads around our way I think you would run out of grip before getting the advantage of the disc power.
    You think wrong, even on the flat, in bone dry conditions discs are markedly better.
    I’ve got two bikes with rims brakes, one with Dura Ace and one with Ultegra, they’re both very, very good, I’m not saying anything to the contrary, but discs are better. I still love my summer bike with rim brakes, but it did make me a bit sad to take my ‘second’ bike to the Alps because the brakes were better, even if I was very glad I did.
    freeagent
    I’ve got both – Giant Defy with 105 level rim brake, Pacenti Rims and Greenstop pads and an Arkose with ‘105’ level Hydros.
    The Giant is fine on dry roads, but pretty scary in the wet.
    The brakes on the Arkose are tempremental (had some issues with callipers leaking, which led to total rear brake failure at one point) but when they’re working properly, they’re very good, loads of power/modulation and can be locked up at any speed on any surface if I really want.
    When the time comes to replace the Giant, it’ll be with a hydro-Disc ‘summer’ bike.
    trap6
    Sorry too hijack op,I’m about too click buy on some disc road wheels,what’s consensus 6 bolt/centre lock?
    crazy-legs
    Pros manage fine because they’re often not doing stupidly technical, narrow road, steep road stuff. On my holidays in France, Spain, Italy etc I’ve used roads that the pros would never go near – chuck in a few steep switchbacks, some gravel, an oncoming car and I’ve had some super hot rims before.
    The Etape du Tour a couple of years ago, descending Columbiere, there were people blowing tyres all around me. Initially I thought it must be tacks in the road but it was just incredibly hot.
    Discs every time.
    Garry_Lager
    Pros are often running tubs, as well, so no problems with carbon rims. If you use carbon clinchers, which I guess are quite popular on higher end bikes, then taking the brake surface off the rim seems like one of the best arguments for disks.
    forzafkawi
    Don’t forget pros use tubs as well not clinchers. The biggest problem they face is sometimes the heat build-up with rim brakes melts the adhesive and the tub unseats. There have been many crashes on descents over the years due to this.
    steve_b77
    I’d have one of these to be honest.
    chakaping
    There’s a lot going on there, beautiful frame but something’s not quite right on the build.
    I think maybe it needs a black chainset?
    mrblobby
    steve_b77… is lovely, but the price 😕
    That and black hubs too.
    Didn’t know they’d stopped doing the Pilgrim. New one on the way looks pretty good though more “adventure” than pure road.
    steve_b77
    I like the shiny chainset, it goes well with the bare stainless at the BB area.
    I agree on the hubs, I reckon silver ones would look a whole lot nicer
    aP
    My best road bike used to have the single pivot Chorus rear brake which was great until it rained, then it became quite scary. Since replaced with Chorus DP brakes front and back. I most recently rode this in Italy in June at the GF Eddy Merckx and on roads in and around Lake Garda beforehand and it was perfectly fine and worked very well. Last month I rode my Bokeh with eTap HRD in TuscanyRoad’17 (mutli-day packed) and the disc brakes on that bike were great too – they have a good level of feel and also because I ride that bike with 38mm Compass tyres the grip was astounding – even on a tight hairpin descending off the Passo del vestito when I found a car about to occupy the space I was about to go into…
    njee20
    That Bowman needs to lose the skinwalls and have plain hubs/headset, far too much Happening. Then it’d look great.
    Daffy
    chakaping – Member
    EXACTLY my thoughts, too.
    Daffy
    This would be my choice.
    anagallis_arvensis
    Just got a road bike with discs, its pretty odd as I find myself taking that early pull to clean the rims before the real braking starts and just slowing down too soon! Guess it’ll improve. The brakes are Spyre cable thingies, not much if any more raw power but so much more feel and realibilty as the above example shows.
    mooman
    FunkyDunc – Member
    I admit, I very likely had too much air pressure in the tyre that popped off. It was about 80-90psi at the time, – but as others have said, the pros wont be using their brakes as much as us mere mortals who have to be aware of traffic coming up the other direction as we descend. Anybody who has ridden on Gran Canaria will know that a lot of the descents are very long, very steep, with often very sharp hairpins; descending the VoTT and the GC210 for example.
    vdubber67
    I still can’t get over the feeling that having discs on your road bike make you look like a complete chopper though….
    Blazin-saddles
    I’ve got a Colnago C60 with DA and Reynolds Aero 46 wheels and a choice of Mavic Exalith rims too which I love dearly.
    After decending the Mont du Chat (Ritchie Portes tour ending crash) in the summer, I’d sell the lot for a hydro disc option as that was frankly scary on rim brakes. I’ve done a lot of big mountain decending over the years on the road, and that was bad, with overheated carbon rims.
    onandon
    Only one of my five road bikes has rim brakes. It mountenous where I live and a wheel delamination scares the shit of of me if I’m honest. There are plenty of down hills where you’re between 30-40 mph into a tight corners for up to an hour at a time.
    In this environment a disc bike is far far better in every way.
    For a blast on the flat, my rim brakes cervelo is awesome and still probably my favourite bike.
    Ultimately it comes down to buying the right tool for the job.
    We all live in different places and have various degrees of riding ability so buy whatever you feel suits your environment and skill level.
    epicyclo
    vdubber67 – Member
    Aye, but if you ride your bike instead of look at it…. 🙂
    reggiegasket
    Haze
    Discs will be on my next winter build, if only to avoid rim wear.
    Summer bike gets raced so won’t be switching to discs until it’s allowed and I’ve got enough of a budget.
    mrblobby
    It is a more common sight but there is still a whiff of this about a road bike with discs 🙂
    Speaking to the LBS by far the majority of their road bike sales now have discs.
    jam-bo
    to 99% of the population a grown man in lycra on a bike looks like a ‘complete chopper’ so run whatever brakes you are happy with…
    TiRed
    “The difference is… I make this look good”.
    It’s the latest thing in road bikes to sell more road bikes. The UCI/BC position isn’t relevant to most riders anyway.
    One day I may succumb. Just not for a while. But it would be on a best bike for mountains not a winter bike that stops fine (I’m not very heavy) in the wet.
    onandon
    ^ this.
    The other day I commented to my wife about how sad a tasseled leather clad Harley rider looked having his mid life crises.
    She said FFS, you ride around in skin tight red camouflage Lycra.
    Fair Pont well made 🙂
    dragon
    Hydro discs are worth it for ‘normal’ riding. But they do have a few negatives, heavier wheels and brake rub, which is not an issue for normal riders but could be if you were racing. (Anyway you hardly brake in most lower level UK road races anyway.)
    Avoid cable operated calipers they simply aren’t worth it IME.
    Aside: All the bike posted on this thread are minging, that Bowman particularly so, although that’s nothing to do with discs on them.
    amedias
    It mountenous where I live….There are plenty of down hills where you’re between 30-40 mph into a tight corners for up to an hour at a time.
    Where do you live? hour long downhills sound like amazing fun!
    Probably not a case of ‘normal’ use for most people though, a case of pick your bike for your riding.
    I have disc and rim brake road bikes, still think for most use I’m happy with the rim brakes, the times when I want/need the discs are only in really shitty weather and generally that’s not that often, even in the UK.
    If it’s a one bike for everything choice then I think I’d probably go disc, but while I have the option of multiple I tend to go with the rim braked bike 90% of the time and keep the discs for a crap weather bike.
    Blazin-saddles
    Dragon- you’d better post a picture of your bike so we can critique it. I quite like the Bowman, just not with the odd coloured hubs and headset.
    onandon
    Rim and disc wheels can be heavy or light. Brake rub is non existent unless there is an issue that needs fixing.
    I’m pleasantly surprised with the lack of rub with my road discs.
    dragon
    Unless you are dragging them, then that shouldn’t be an issue. Sit up, break, off brake corner, sprint and repeat. Brake should have plenty of time to cool between bends, even if they come fairly quickly.
    Blazin-saddles I don’t have a pic of mine to hand but here is the website shot of mine. I actually wasn’t keen on the colour when I got it, but i;s grown on me. (Yeah I know it’s not strictly a road bike, but it is used as my all year road bike, my summer roadie has calipers.)
The topic ‘Road bike… Rim brakes vs discs.’ is closed to new replies.
