I’m in the process of putting some brakes that might work on the pub bike aka the singlespeed aka the station bike. This is an old 1970’s Raleigh something that has morphed over time. It was a 27″ bike, but currently has some 700c wheels installed. The brakes were a set of cantilevers which never really worked and I’d like something that may actually stop you. I have a cheap set of standard road bikes brakes, but the problem is when installed the brake pads will brake nicely on the tyres, not the rims.
Hence I need some longer “arms”. I’ve seen brakes such as the Tektro R559 but am confused as to whether longer arms means that the brakes can deal with wider tyres – or actually have a longer reach (i.e. the distance from the crown to the rim).
Anyone had this problem before and solved it? If so how? Is the option above possible?
