My reverb has packed up. Think a seal has gone, pump on the lever and nothing happens (I can hear liquid movement inside seatpost if I listen carefully). Seatpost was getting a bit sticky beforehand. Done the obvious bleed and psi check, also disconnected barb from seatpost and hose+reconnected. I can pull the seatpost up (its stuck 1/2 way).
Anyone serviced a reverb inside with success? I’m a bit worried to, although I have serviced pace, manitou, rockshox, fox, xfusion forks plenty of times, I’ve not gone into a reverb.
If not, any local service centres (Portsmouth area) or should I send it off to Loco (£70+del).
Thanks
Dave
