Viewing 7 posts - 1 through 7 (of 7 total)
  • Reverb question
  • Underhill
    Do the 380mm & 420mm both have 125mm drop? 380 would be the right length for my Pitch, but don’t want shortchanged on the drop
    craigxxl
    The drop is the same, the inserted seat post is different. If you don’t need the extra then keep to 380mm
    Underhill
    That’s what I was hoping. Cheers
    AGray
    Can you cut the seat post if needed or is the full post sealed?
    Underhill
    Don’t think I’d want to cut the post on a Reverb.
    marko75
    is it possible to shim the seat tube to fit a reverb….. according to RS this is not possible but I cant see why not?
    Hob-Nob
    I have shimmed mine. I run a 30.9 post in a 31.6 frame & it’s fine 🙂
The topic ‘Reverb question’ is closed to new replies.
