Viewing 9 posts - 1 through 9 (of 9 total)
  • Reverb leaking oil from schrader valve?
  • bluearsedfly
    Just topped up the air pressure on my Reverb and when I disconnected the pump along with the ‘puff’ of air I received a complementary mist of oil.
    The same happens every time I reduce the air pressure or remove the pump. Short of not reducing the air pressure or removing the pump I presume it requires some attention?
    mildbore
    Mine does that every time I check/adjust it, don’t think it’s a problem but then I’m guessing
    bluearsedfly
    I’ve had a few before and none have ever has this problem (although I’ve had every other Reverb problem).
    Had a look around and can’t see much mention of it.
    LoCo
    If there’s a lot of oil coming out you have an issue, but then the post will probably not be functioning correctly.
    If just a ‘mist’ probably ok but keep an eye on it.
    bluearsedfly
    Thanks, tried it again since and it is getting worse.
    Is it a two year warranty on the Reverb?
    mildbore
    Yep 2 year warranty, just sent one back this week after it stuck down in the cold weather a week ago, it’s 19 months old
    mildbore
    LoCo
    If getting worse you’ll have issues fairly soon, return to place of purchase for them to return to SRAM for a warranty inspection.
    Warranty is 2 years
    bluearsedfly
    Thanks, it’s now winging its way back to Sram.
The topic ‘Reverb leaking oil from schrader valve?’ is closed to new replies.
