So I got to the first descent of last Saturdays ride and found having dropped my Reverb it wouldn’t return (leaving me to ride the rest of the route like I was on a BMX). I checked the pressure (was fine) and bled the remote (got quite a few air bubbles back) and now it works.
When it popped back up though I noticed the black bushing collar was loose – I’m not sure how long this has been the case but on lifting it up things didn’t look in bad shape. Still seems to be grease in there and the shaft looks clean and ‘wet’. I’ve just dapped a bit of loctite on it and nipped it up with an adjustable.
But on googling I’ve seen some folk suggest that I should do a service after this (the post is >2 years old – a warranty replacement for another post). I’m not sure if it’s more hassle than it’s worth right now though, the RS video takes 18 mins just to go through the steps quickly so I’m guessing it’ll be a good few hours for me to do. I’ve got most of the parts to do a service. Also is it entirely necessary to do the whole thing? is there some kind of lower only half way house? I’d guess this is where most of the crap would accumulate. I’m confident with servicing my forks but this seems to be a bit more of a PITA.
If it’s not broken don’t fix it
or
A stitch in time saves nine
which Idiom is it?
Mat
