Reverb is not retur...
[Closed] Reverb is not returning. Bleed or add air?
[#3952362]
I shortened the hose.
First ride it worked fine but tonight it's return speed (its on the fastest setting) got slower and slower and it's now given up and is stuck at the bottom.
Am I right in thinking that it needs to be at the top before you attach a pump?
Checking the air seems easier than bleeding it as a first step 🙂
Posted : 07/05/2012 10:11 pm
might be worth trying the air. Mine hasn't been shortened but the return speed was always a bit slow (and seemingly getting a bit slower), check the pressure and it was around 60PSi! Funnily enough it works a lot better now 😀
Posted : 07/05/2012 10:13 pm
Not sure about adding air but it needs to be at the top before a bleed. You can actually pull it up with your hands if need be.
Posted : 07/05/2012 10:16 pm
Sounds like the beginning of the end, is it a 2011? Mine is on its 3rd set of air seals now!
Posted : 07/05/2012 10:19 pm
It's nearly new and according to bike-discount-de it's 2012..
Posted : 07/05/2012 10:23 pm
Bleed.
Mine was doing this until I bled it - works fine now 🙂
Posted : 07/05/2012 10:34 pm
Bleed makes sense since I've just shortened the hose. Guess I'm fishing for an easy solution..
Posted : 07/05/2012 10:37 pm
Have you tried it with the seatpost QR undone ? It's possible to deform the Reverb enough with a tight seatclamp that it won't function.
D.
Posted : 07/05/2012 10:58 pm
Mine always struggles with the final 10mm or so. Not sure if its the way I've got the cable routed. Is there anything I can help it with this final bit? Always stops slightly short whether its on fast or slow.
Posted : 07/05/2012 11:13 pm
Davesport, no, but then again it worked ok for at least 8 rides and I haven't altered the clamp.
I will try it though tomoz and let you know.
Posted : 07/05/2012 11:21 pm
I'd say add some more air in, thats what was happening with mine. However now it would seem the bushings have gone so It needs to go back for a service 🙁
Posted : 08/05/2012 9:15 am
One of mine is doing a similar thing. Its losing pressure over a 10 days period. So its back to Wiggle next week as it looks like its the seals.
Posted : 08/05/2012 9:26 am
So will I blow my pump up if it's full of air?
Posted : 08/05/2012 10:35 am
Not unless your pump can't handle around 250psi (potentially). A decent shock pump will be fine.
Posted : 08/05/2012 11:21 am
Also check the post is clean and lube the seal with suspension lube.
Posted : 08/05/2012 12:16 pm
Ta folks, I'll give it a go tonight along with loosening the seatclamp.
Posted : 08/05/2012 12:29 pm
Looks like its leaking from the shaft of the push button. Now where's that thread about changing tyres.. 😐
I've emailed Fisher about spares.
Posted : 08/05/2012 10:17 pm
