Just adding some notes following a service of some Fox Float 32 RL forks (open bath type) for those investigating failure to lockout in future.
Fox Oil Volumes for this fork state 160ml in the damper side. I followed this to the letter.
Result – no lockout after service.
Action – added a bit more oil (approx 5ml) – Now locks out perfectly.
I’ve concluded that the specified oil volume given by the manufacturer is the perfect amount to just about give lockout. What this volume does not take into account for the home mechanic is the small amount of loss in the measuring vessel and/or syringe used to inject the oil.
Therefore, read the manufacturers specified volume, add a bit and you’ll have perfect lockout. Has worked for me on several Rockshox forks and now also on Fox.
Top tip is not to add too much. Although you’ll be guaranteed to improve lockout, you’ll be reducing travel and potentially causing other unwanted side effects with the increased oil pressure!
