I very recently bought the wife a second hand set of the above forks from 2014 for her new bike. They’d had a lower service and check by the sellers LBS prior to the sale and all seemed well when they arrived and for the first three rides.
She came home yesterday from a weekend away and now the three position dial is stuck and can’t be turned, plus the low speed compression dial just spins and spins (with clicks). I assume this means that the damper is toast? Or at least the lock out part?
If they are knackered and I assume this is the case, I have a set of the same forks but 26” flavor that I was going to sell. I assume I can just lift the damper out of one fork and drop it in the other whilst adding some new 5wt oil?
Just to be clear, I’ve no issue with the seller, buying second hand is luck of the draw so no pitch forks unfortunately
