Removing pins from ...
[Closed] Removing pins from a flat pedal
[#2826149]
I'm changing pins over in a 2nd hand pair of flats, except it would seem quite a few of the traditional top-hex-bolt-head type don't want to budge and have rounded off. (always thought this was a bit of a design fail)
Anyone got any brainwaves on the best way to get the little buggers out before I start getting busy with the hacksaw?
To clarify the pin type:
Posted : 07/06/2011 11:43 am
Mole grip very tight on the sticky outy bits.
My surgeon had to use them on the bolts in my hip when he rounded a couple off trying to get them out, so they're not always the wrong tool for the job...
Posted : 07/06/2011 11:44 am
 taka
Drill em out
Posted : 07/06/2011 11:45 am
set of large pliers or mole grips.
Posted : 07/06/2011 11:48 am
Penetrating fluid, or get a hacksaw and cut a slot in the top to take a screwdriver.
Posted : 07/06/2011 11:50 am
 5lab
mole grips
Posted : 07/06/2011 11:52 am
OK. Molgrips out, hacksaw primed.
Cheers!
Posted : 07/06/2011 1:41 pm
Two down, one stubborn git to go.
Then it's onto pedal number two.
Posted : 07/06/2011 4:21 pm
Thru pins FTW
Posted : 07/06/2011 4:28 pm
Thru pins FTW
They do have thru pins too, which are good.
TDH, I think these are the way forward:
Posted : 07/06/2011 4:30 pm
Good luck PMJ.
The best ones I've found are the thru pins. I've just changed mine on my superstar nano's and it was stupidly easy. On the straitlines there's a few that are bashed and hard to get out.
Posted : 07/06/2011 4:56 pm
