I commute on a pompetamine. I think it may be due some new wheels. I built it myself and was lucky in that the 6 bolt hub just about clears the fork. There was an issue with the bolts on some hubs fouling and causing problem. Bit worried about shelling out on some wheels to find they don’t work.
I remember the original advice being to use centrelock but that limits me to shimano? I don’t want to ever use cup and cone wheels again so that is a no go. Cheap is essential, I was think Superstar/Prime or similar around £140
Anybody remember if other solutions were available. So far google has thrown up various options of different severity.
-Use low profile bolts (limited chance of success)
-Use a small shim on each side of the hub. Steel for so should be ok for the 0.25mm or so needed.
-Bash the fork/create a small dint in the area where the bolts touch.
new cheap fork is also an option but not many about.
As it is due a substantial rebuild (wheels, drive chain, tyres, cables, BB, bar tape) I am thinking of just replacing it but it seems a shame as it still just works.
