I’ve got a nice Rega Planar 3 I’ve had for about 20 years.
I like it very much. It’s been serviced recently and sounds great.
Unfortunately, over the years the two hinges on the lid have broken, across the flexible plastic hinge itself.
I can get a new lid for £80, or a new pair of hinges for a tenner.
Unfortunately, I’ve no idea about how to remove the pop rivets that hold the hinge to the lid.
I assume I’d have to drill them out, but I don’t want to damage the lid.
Not confident about re riviting the new hinges in place either.
I could just use nuts and bolts with rubber washers, but it’ll look a bit shonky.
Local HiFi place reckon they can fit the new hinges for about £30.00, but I fancy giving it a go myself.
I’d use a drill a bit bigger than the hole. You don’t want it to be too close to the size of the hole or it might jam in and start the rivet spinning which will melt the Perspex
Drill from the outside of the lid to the inside so you can put a block of wood inside to push against
Use a reasonable high drill speed to stop the drill catching
If you need to drill for more than a couple of seconds then stop and cool it down with water. You don’t want the perspex to melt
