Reducing travel on ...
[Closed] Reducing travel on Fox Float 120
[#2031704]
Can the F120s (2010) RLC model be reduced to 100mm travel, and if yes how easy is it to do?
ta
Posted : 27/09/2010 2:35 pm
yes, very easy. No harder than a strip and oil change (doesn't even need to be that involved if you're careful but never hurts to change the oil) Mojo do reduction spacers in a varity of lengths.
Posted : 27/09/2010 2:41 pm
 LoCo
Have a look at this:
http://service.foxracingshox.com/consumers/index.htm
Posted : 27/09/2010 2:44 pm
Thanks, so if I reduce the 120 to 100 then with a spacer does the fork crown / axle height also get reduced by 20mm or is this going to be a fixed distance ?
Posted : 27/09/2010 4:08 pm
It reduces the axle/crown height too I believe
Posted : 27/09/2010 4:12 pm
What would be the point of reducing the travel if it wasn't going to reduce the axle to crown height?
Posted : 27/09/2010 4:15 pm
Preserves your angles??
Posted : 27/09/2010 4:47 pm
drop the travel by 20mm and the a2c reduces by 20mm
Posted : 27/09/2010 8:27 pm
 RRD
Does it really change the a2c? I was under the impression the addition of the spacers only reduced how much the lowers moved up the stancions??? I know this seems counter intuitive but I could not find any information mentioning new a2c dimensions (similarly you do not "cut" 20mm of the bottom of the stancions... I caveat this comment by stating I'm not an expert
Posted : 27/09/2010 8:39 pm
bigyinn - Member
I don't think you understand what I'm getting at - what would be the point of reducing the travel if the only thing it did was make the fork less effective?
Posted : 28/09/2010 1:15 am
absolutely which is why I want to be certain that IF I reduce the travel it will reduce A2C height also (as running a 120 on a frame really meant for 100----BUT the A2C on the Fox is only about 10mm more than my previous 100mm fork)
Posted : 28/09/2010 8:19 am
