They don’t even need to meet them if pushed, though it’s good practice to do so, a copy of a passport and a couple of signed docs can do the job if needed.
Our auditor said the original need to be seen and checked, otherwise how would you know if they are real? (i assume you accept email copies?)
in our case we had a copy of the workers passports on file (emailed over) but the passport numbers where identical on several which kicked off the investigation.
https://www.gov.uk/check-job-applicant-right-to-work
You must see the applicant’s original documents
You must check that the documents are valid with the applicant present.
You must make and keep copies of the documents and record the date you made the check.
You could face a civil penalty if you employ an illegal worker and haven’t carried out a correct right to work check.
Checking the documents
You need to check that:
– the documents are genuine, original and unchanged and belong to the person who has given them to you
– the dates for the applicant’s right to work in the UK haven’t expired
– photos are the same across all documents and look like the applicant
– dates of birth are the same across all documents
