santacruzsi – Member
Thanks. I’m right at the beginning, like holding the instrument the right way up / down beginning!
Just remember that initially, it’s all about getting strength into your fingers, which you’ll only get by picking it up and practicing daily for 15/30minutes. (Which is also an ongoing thing as you learn more, people struggle because their fingers aren’t used to something, it’s a thing that’s very noticeable if you’ve not played the guitar in a few years and you go back to it, you know what you want to do, but your fingers don’t have the “fitness” to keep up with you brain.)
Obviously that’s massively simplifying things and there’s alot more to it, but I think it’s a reason why a lot of people think they can’t play the guitar, which is nonsense, anyone can play the guitar, you just need to put the required effort into training yourself.
I’d also say if you are really struggling with something, don’t stick to it forever, leave it, try something else for a week and then go back to it, you’ll find that you can probably play it. This is for a couple of reasons, in that guitar practice isn’t linear, if you learn one thing, it doesn’t just benefit one thing, it “levels you up” across the board. That and after a week, your brain has had time to process what you learned the week before, so it’s then easier to go back and master something you’ve tried before after a break from it, that and your fingers have had some previous training at it…
Main thing, don’t get frustrated, try something different if frustration kicks in(frustration is a route to chucking it), ultimately learning the guitar should be enjoyable, first and foremost.
