I'm generally a large size shirt but at 5'8" they're too long and hang right over my arse! I'm after a couple of going out shirts that hang to about the belt line on jeans but aren't too tight on my 'tremendous' chest and shoulders ;). Any recommendations from similar shaped bods?
I loath going clothes shopping and don't want to waste my time in shops any more than I have too.
James
Peter Werth always seemed to fit me well. I'm a bit shorter but fairly broad so sometimes have similar issues. Or had, been a while since I shopped for clothes…
Merc,the construction quality and the detailing is really good, I've got quite broad shoulders and chest, but slim hips and waist and I'm 5'7". I've got about seven or eight of their shirts and they are a good untucked fit. For dress shirts, try Ted Baker, I've got a few of them as well…….
Merc shirts generally from about 40/60 quid and Ted Baker from about the same, maybe a little higher.:)
I bought a stack of shirts when I was last in the Far East, all made-to-measure. TBH cheaper than dry-cleaning. Often you see adverts for these guys in the London area?
TM Lewin do shirts in a variety of fits. So you can achieve a semi -tailored look whatever your size. You can get them over the net. Charles Tyright I believe do a smiliar thing.
M&S made to measure. Good choice and very very good value for money with killer customer support if you do have an issue.
I've been buying them for a while (now have six) and the fit is great, I was sceptical at first about how they'd fit based on the measurements asked for but they are spot on for my weird shape.
Lewin aren't the right fit for the stockier chap, as they are rather slimmer cut and longer in the sleeve.
Pink shirts are guff and have been ever since they were taken over and production moved out of the UK.
Disagree. I wear TM Lewin (mainly because I'm tight – they're cheap for a reason), but as a stpckier chap, I find a 16" collar, 33" sleeve and their slim cut to be a reasonable compromise (at £20 a shirt, that's pretty good).
Well said that man. Godawful. actually, prob no worse quality that Lewins, but they are designed for fat people with long arms.
Your error, OP, as a short and broad man is to wear your shirt untucked. It will only make you look shorter and broader. Buy a shirt with tails (i.e. designed to be worn tucked in) and wear that.
Only darts players and ten pin bowlers think the untucked shirt is a good look for being seen in public.
"Alexander McQueen Tend to be a bit tight round the neck but they hang well" nasty, but very funny!
Cheers for the feedback and the general lack of piss taking!
