Viewing 3 posts - 1 through 3 (of 3 total)
  • recommend me a 2x dropper lever with clamp at lever end..
  • fitnessischeating
    I have a e13 post that I use on one bike that I would like to swap onto another, however this is running a 2x system (quiet down at the back, I’m happy and thats what counts!)
    So, I can’t use a 1x remote
    as the e13 has the cable end at the bottom of the post, buying another lever will make it easy to swap the post between bikes….
    so, the fox 2x lever looks perfect, but is £60ish…. any other good options?
    Andy-R
    Sorry – ignore me, I didn’t see the 2x bit…….
    dai3015
    Have a look at Triton cycles – they sell a Bontrager “2x” remote that has a grub screw that tightens the cable – I picked one up for my internally routed TranzX and it works fine. A little agricultural, but only £14 so can’t really complain (also bought the 1x lever as well in case I decide to ditch the double at some point, again only £14)
    David
The topic ‘recommend me a 2x dropper lever with clamp at lever end..’ is closed to new replies.
