Picked up some used 2013 Reba RLs to fit my Solaris, replacing my older Reba SL dual air I have put on a friends bike and am very, very unimpressed.
The old dual are were absolutely lovely responsive forks with the tuning of the dual air both my 85kg and her much lighter weight but these solo air feel like they are locked out at the recommended pressure.
Aware of the problems with blocked air port to gave them a service and they improved a bit. Air is getting into the negative chamber as confirmed by pressing the hidden valve under the air spring shaft bolt but I just cannot get the sag or initial bump sensitivity right. Damper seems to be working okay but want to get rid of the remote lock out so I can adjust the compression damping.
Options seem to be:
a) Top out bumper mod
b) replace with 110mm dual air spring
C) try and fit an extender bolt to the air shaft to mount the negative valve externally thus adapt them to dual air and fit a spacer to stop them equalising
d) sack off the air spring and fit a 120mm recon coil spring but that seems a shame after how well my old dual airs used to feel.
