Interesting, I’ve got the rebound basically open, which makes my old floats nice and supple.
Completely different fork, ignore all that and don’t use those as a reference.
In the main the RS forks are delivered too linear. The easy fix to this is to add more air, which makes them less supple / small bump sensitive and will speed up the rebound due to an increase in “spring” if you don’t adjust the rebound.
To fix, add tokens and use less air. The first part of the stroke becomes more sensitive to small bumps due to the lower air volume / softer spring but the fork ramps quicker and avoids dive because the air chamber has been reduced and that air compresses more earlier in the stroke.
Adding tokens is very easy. You can get a pack of 5 from Amazon for £10 and is a 5 min job you can google, as there are many videos on the internet. Basically, remove top cap, remove air, unscrew top cap assembly with 24mm socket, screw/unscrew tokens and reverse.
I have the same forks in 120 & 100mm and have just done this to mine. Its a huge improvement.
