I was riding my MBT the other day and realised that the rear wheel was nearly rubbing the right hand side chain stay, yet the wheel was aligned evenly between the seat stay.
What could be the problem and what should I do first? Or just take it to the LBS
1) undo QR, reset wheel, do up QR, check again
if wheel not sat up in the drop outs properly on the NDS then possible mis-alignment
2) take chain and disc caliper off, flip wheel round with cassette on NDS, check again
see if the wheel is out of true/dish. If it is then the wheel will now rub on a different part of the frame
3) check drop out alignment I mean rear triangle aslignment using a bit of string and a ruler. http://www.sheldonbrown.com/frame-spacing.html
Checking Alignment (Symmetry) section near the bottom.
if the drop outs are out of whack, and its a steel frame Id manipulate it back myself. If Al Id take it to a shop for further diagnosis and use of their insurance cover 🙂
