Rear Suspension mea...
[Closed] Rear Suspension measurements
[#1125072]
Help!
How do you measure a rear shock so you can buy an upgrade??
I am new to full sus rigs (old school hardtail previously), but wanting to upgrade. In order to upgrade the rear shock, I need to work out the size to order ...... HELP!
Thanks
Posted : 13/12/2009 12:21 pm
eye to eye (c-c) measurement (when uncompressed) and travel stroke I think are the main ones.
Posted : 13/12/2009 12:23 pm
you need two numbers, eye to eye (centres) and stroke length. ie 190mm i2i, 50mm stroke is a popular one.
hi was thinking the same question the other day
can do it the top way, after working out how far it compresses
but suppose you can measure the eye 2 eye length of both compressed and extended and the difference is surely your stroke length
Posted : 13/12/2009 12:44 pm
FANTASTIC - Thanks guys
Posted : 13/12/2009 3:40 pm
What bike is it ?
Posted : 13/12/2009 4:04 pm
the i2i length with the stroke length are a start but you also need to know the width of the shock eyelet and the internal width of the frame mounting points where the new shock is going to sit(incase you buy a different brand of shock, because manitou and fox use a different diameter eyelet so therefore you would need new bushes to fit)
have a look here...it explains everything you need to know
http://www.tftunedshox.com/info/mount_kits_bushings.aspx
and
Eye to eye (mm) with percentage sag
Eye to Eye x Stroke 20% 25% 30% 35% 40% 45% 50%
6.5 x 1.5" 165 x 38mm 157 155 153 151 149 147 145
7.5 x 2.0" 190 x 50mm 180 177.5 175 172.5 170 167.5 165
7.875 x 2.0" 200 x 50mm 190 187.5 185 182.5 180 177.5 175
7.875 x 2.25" 200 x 57mm 188 185 183 180 177 174 171
8.5 x 2.5" 216 x 63mm 203 200 197 194 191 187 184
8.75 x 2.75" 222 x 71mm 208 204 200 197 193 189 186
9.0 x 2.75" 230 x 71mm 218 214 210 207 203 199 196
9.5 x 3.0" 241 x 76mm 226 222 218 214 210 206 203
Posted : 13/12/2009 4:27 pm
Its a small Norco Fluid LT3 (2008). Got a Fox DHX Air 3.0 at the mo
Posted : 14/12/2009 3:52 pm
Fisher Outdoor Leisure
Phone: +44 1727 798345
Email: sales@fisheroutdoor.co.uk
http://www.fisheroutdoor.co.uk/fisheroutdoor.html
Think they are distributed by Fishers, ask them for exact details.
Posted : 14/12/2009 4:09 pm
worth phoning mojo to find out what compression and rebound tune works best with your shock as well as each one comes with three levels of tune depending on your frame, i have two turner 5 spots one with push (long) rockers and one with stock rockers and the pushed one works better with a high tune and the stock one works best with a medium tune, worth a phonecall to find out imo
Posted : 14/12/2009 4:21 pm
