Bike Whyte T120 (120mm) with Monarch rt high volume rear shock.
Manual states strick requirement for 25% sag to be set, which for me at 93kg is 240psi. Once set the bike is supple over small bumps etc but the rear shock ramps up so much I get no where near full travel.
The stock on the shock is 51mm and no matter what I ride always have 15 + mm left. Not on about mighty hucks or anything but I have done a couple of 3ft drops to flat to try and get further through it and same result.
So when I am hitting rocky sections its ramping back up and effectively to me not behaving. I want the shock to get further into the travel as I did not buy an 80mm travel bike to kick me back in the arse so readily.
Any thoughts – different shock maybe, experience etc, retune. The shock is factory set with the low compression tune and I run it fully open on the gate and with quite a bit of rebound on.
