You should definately stick with the same eye to eye and shaft length, the geometry may be adversely affected otherwise.As for rebound or compression, if you,re happy with the current settings you may want to stick with similar settings on a new shock, however, damping settings will vary between manufacturers and even within a given manufacturers product line do vary. I believe that Arios have basic damping. Monarchs can be adjusted with volume spacers cheaply from CRC or elsewhere. If you,re not sure on rebound or compression settings you may want a shock that is more adjustable, such as a Fox RP23 or a Cane Creek DB. These are more expensive though and getting the right feel may take longer through trial and error.
