the driveway is surfaced with different sized flags and the pointing between them is beginning to disintegrate.
What does the STW hive mind reckon is the best way of re-pointing is??
I'm sure I saw someone on telly brushing in a dry sand/cement mix then wetting it down and letting it set.. will that work?
I also guess I've got a fun job in chipping out the old stuff as well..!
ta
