I would say it depends if its 2017 or 2018 forks. The 2018 Pike/Lyrik is a big step up over 2017, so its not as simple as RC Vs RCT3, its also which year. Yari / Revelation RC have a better chassis and air-spring that the 2017s but other wise equivalent, whereas Pike/Lyrik are improved across the board. So as its a new bike, if it was a 2018 Pike RC v RCT3 I would say no you’d not miss the RCT3, as the RC damper in the 2018 is still better than the RCT3 from 2017, but for a Yari as you mention, the 2017 Pike RCT3 damper is still better, but the 2018 chassis and air-spring on the Yari wins, so its probably closer to a draw.
