Random... how easy ...
[Closed] Random... how easy is it to fit a carpet yourself?
[#3212514]
Finally nearing the end of decorating the last of the spare rooms (after 6 years in the house!) and it needs a new carpet. Want to try and save as much money as possible and just get it finished so how easy/hard is it to fit a carpet? Room is about 12ft x 12ft but has two alcoves either side of a chimney breast.
PITA or easy enough? Any tricks of the trade and/or essential tools? Already has underlay down so thats fine...
Dave
Posted : 05/10/2011 9:25 am
Easy to mess up.
I'd get someone in myself. (but then I'd say that anyway)
Posted : 05/10/2011 9:29 am
Like everything it's easy if you know how.
I have done easy square rooms but never stairs ect...
Posted : 05/10/2011 9:31 am
Does the room also have grippers down?
It is relatively easy to lay, but getting it nice and flat is trickier - you really need kickers to pull it nice and taught and it is also easier if your skirting will allow the carpet to tuck under it.
I laid my own carpet in my bedroom aged 16 and it went down okay really.
But if it were me, I wouldn't put new carpet on old underlay especially if it is 6 years+ old.
A kicker earlier...
Posted : 05/10/2011 9:32 am
Like much stuff its relativly easy for the amateur to do quickly [i]or[/i] well. The pro will do booth.
for the cost of a pro fitter I would use one myself
Posted : 05/10/2011 9:38 am
Ohh and as for tools - a wide cold chisel (3'' + ) does a good job of feeding the carpet under the skirting but clean it first 😉
Don't use a screwdriver or you will risk ruining the carpet before you even lay it.
Posted : 05/10/2011 9:47 am
Yeah it's easy enough to do an ok job. It'll take a bit/lot longer than a pro and it won't be quite as good but if you're happy with that then go for it
Posted : 05/10/2011 9:52 am
Ohh and another thing - if you are doing it yourself make sure you measure carefully.
Then check again.
Then do another measure to be on the safe side.
Then check.
Then cut. (But just check first).
With a nice NEW blade.
Posted : 05/10/2011 9:53 am
I use sharp knife blades. They are cheese compared to the lads I know who fit carpet. You need those ones with a curly pointy blade. Otherwise it's very easy for your cut to run out on you.
Posted : 05/10/2011 9:58 am
Like me and my flooring. DD where were you in 2007? 🙂
Posted : 05/10/2011 10:04 am
Probably not wasting as much time on here Molly 😀
Posted : 05/10/2011 10:38 am
As others have said it's easy enough to do to an okay standard.
Posted : 05/10/2011 11:03 am
dead easy.... lay out new carpet measured to roughly what you need (over estimate) put old carpet on top, cut round it (leaving an inch or so round each edge. Roll up new carpet, take it upstairs and lay it down. trim edges with a sharp stanley knife. If it starts to drag, change the blade. Expect to get through a few blades.
A bit of carpet glue and proper door strips will keep it in place.
A pro standard job will involve gripers and those tools above, but I've never used them, and its always looked fine. Though I'm due to do some stairs soon, so might need to invest, as I don't fancy carpet on the stairs moving at all!
Posted : 05/10/2011 11:37 am
